Originally posted by finn17
concern was expressed about some of the chemicals in milliput being easily absorbed through the skin
In an ideal world we would all use a Barrier-cream when mixing
any putties. You can get it from most good harware shops/stores, just rub a pea-sized amount into your fingertips and there you go. If you have any small cuts or wounds on your fingers you really ought to consider it essencial.
Err...and Lurch, if you really have done a bit of DIY dentistry I seriously recommend you
get that stuff out of there. You may believe it to be safe \'cos it\'s not labelled \'toxic\' but that doesn\'t mean your body will not adsorb a material it is not meant to cope with, possibly making you very ill. When you swallow something you\'re not supposed to, you only absorb a limited amount before it passes out of your body but if it is
always present in your body (or mouth) you will continually be building up the levels of toxins until they are sufficient to make you ill (or, at the very least, delay healing and cause infections). Sorry about the rant, but I couldn\'t forgive myself if you died of mouth-cancer and I\'d kept quiet.
