Hi, I looked at where abouts the mould line is on the piece I wanted to copy, got a blob of G.s. about twice the size on a bit of thick polythene, roughed it out to a rectangle shape the would accomadate the original.
I coated the the original thinly in fine grade oil, very thinly so it\'s easier to get out of the GS, talc is probably better though, and pushed half of the piece into the GS using the mould line as a guide.
When it\'s completely set, repeat with the other side., coating the set GS with oil/talc so the two halves don\'t stick
I\'ve had results ranging from acceptable to throw them straight in the bin.
Worked ok with an assault cannon, but the heads I tried were naff and I ended up sculpting my own.
Good luck.
