Originally posted by nick232
vinyl paper is the stuff you make them form, and use masking tape to stick it down!
Originally posted by gothicgeek
print your design ( on standard office type paper ), cut out with a nice sharp blade ( i always print about 10 so i can mess up a few times)
beg borrow or buy some spray mount or low tack spray adhesive, if it is a bit too sticky your skin is a good source of de-tacker, position and use tape and paper to shield against overspray.
if you want something that will do a few repeats, seal the paper with Klear or an acrylic varnish before applying the spray mount
HTH
Mark
