Help with Blue metalics
Blackstar
okay, I\'ve painted a good chunk of my friend\'s Necron army in a dark metalic blue color scheme, but I\'m at a loss as how to highlight the damn things! I used black primer followed up by boltgun metal and then inked with blue ink (all GW). The paint job works great for the tabletop and has actually gotten me a few kudos, but I want to make them look even better as my friend has done a lot for me and I want to make his army stand out. Any and all help is appreciated!
Ritual
I\'d try mixing Mithril with a little blue ink and then applying thin glazes on the areas you want to highlight. If you keep the layers ultra-thin you will have good control over things and can decide how far you want to go with the highlights.
Galante
Hum... Have you tried highlighting with pure boltgun metal and a mix of BM and mithril silver, then giving it a blue ink glaze?
Ritual
@Galante: I assume he don\'t want to repaint all the armour, but rather apply highlights on top of what is already painted.
That sounds like it would work.
Originally posted by Ratcals
Originally posted by Ogrebane
I use water with a drop of detergent. Helps if the paint has big lumpy bits.
Doesn\'t that create suds in your paint?
I almost always use some dishwashing liquid in my rinsing and mixing water, have done for years. There is a mild effect on the formation of bubbles* but it\'s not a big problem unless you\'re brushing vigorously, particularly on a textured surface.
*Also you don\'t necessarily want this if the painting you\'re doing might be helped by higher water tension.
Wolf Fang
mix midnight blue with minthril... the mor minthril u use the less blue and brighter it becomes the more lue u use the darker it becomes... atleast thats the way i think it worked when i did it!
Blackstar
Thanks~!
Thanks to everyone\'s advice, I\'m going to try to try it out this weekend as I\'ve a final exam this Friday and so am spending what little free time I have studying. I\'ll try taking a pic, not my best skill, but will try before and after shot s. Thanks again!
