http://www.sciborminiatures.com/en_,sculpting.php?id=571
He put a tutorial for how to do it via molds , similar to what Cyril did on creafigs some time ago.
I\'ve been trying this as a test...using baked super sculpey (making the molds with plasticard shapes and thin plasticard bent for the arcs), before baking.
Then lubricating with turpenoid, and water. Then using green stuff pushed in and peeling it out for the armour shape.
Problem, how do you ensure the same height for each pattern pressed into the mold?
And the bigger issue, when removing the GS, it starts to bend, etc since it\'s so sticky.
Should it be harder or dry a bit?
Sanjay
Sanjay
