how can a create a rought sea effect?
Carlo.B.
Hello, could anybody tell me how to make a rought sea with waves and froth?? Is there any tutorial step by step? It has to be really realistic, preferably with water effect; the main probem is the froth 'cause I ve no idea of the materials I shoud use,
Thanks in advance!
What scale?
I've seen casting resin picked with a brush (disposable) when it has reached the gel point. Highlight with plaster or with white paint.
Carlo.B.
www.coolminiornot.com/277892?browseid=15619435 here is the effect I d like to obtain, the scale miniatures I m eorking with is 28/54 mm for a small diorama.
Thanks for you help.
Ten ball, your work is lovely and your water effect impressive, I ll certainly try it (thanks!) But in this case I m looking for a more realistic output
Woah...the Great Carlo B asking for advice. This is humbling. I picked you out YEARS ago, when you only had 3-4 paintings scoring in the 8s range in your gallery. I just knew there was something special about your work. Now I just reviewed your work and wow...I should have wagered on your success!!!! Doing great man!
I don't have any advice as I have never created a water base of any kind. Cheers tho
