Grimm Blade
I am building a GK collection and I really want to be able to replicate the metallics from the pics below. Can any of you explain to me how the effect is created or point in the direction of a tutorial on this style please?
Read up on NMM in the sticky links, and study lots of photographs to understand how light interacts with metallic surfaces.
With the top pic, do you think it is a simple as painting the model a darker silver, washing it with Badab black and highlighting with a lighter silver?
That might nearly be the technique but look at the quality, does it look like it was just washed with black for the shading? Regardless of whether it's done starting with a metallic basecoat, the darks are probably glazed on, not applied as washes, because a wash settles into recesses/low spots, doesn't go exactly where you want it (like on the sides of something).Grimm Blade said:With the top pic, do you think it is a simple as painting the model a darker silver, washing it with Badab black and highlighting with a lighter silver?
Looking at the softness of the top pictures initial colours I'D suspect that GW metallics were not involved at all.no. when painting models like these, it´s never as simple as one two three. i´d say around 7-8 layers. tin bitz and boltgun metal as a base, highlighting up to chainmail, a few heavily watered down washes of some tones, and then highlighting from chainmail to mithril silver.
The pigment definition is far smaller/finer than GW's and more akin to what I've managed with Vallejo Airbrush Metallics and a gentle drybrush (using Circular strokes).
I take it Grimm Blade that you've seen these pictures on Coolmini and attempted to contact the originator for advice?
The top pic is mine. And yes i used gw metallic paints. You need to create a lot of contrast to get this look, from black to white YES! the boltgun metal base coat is heavily glazed down in some areas were light would not fall almost to black glazed about 8 times depending on how dark you want it to be. Then you can also highlight the very sharpest points on the armor with white but it must be used very spairingly. the brain doesnt pic up on the white but it makes a difference. i apply it only over the mithral silver as a seconed edge highlight but only where light would fall directly from above.
sorry about that reply Grimm blade i call "glazes" washes some times!?! some people call them "juices"
It took a long time to paint this mini i wouldnt fancie painting a whole army like this no way!
