How do i make that dust/dirt stuff?
matt15595
Hello, i want to make something similar to the dust/dirt from this piece:
http://www.coolminiornot.com/179326
How would i go about painting it?
Im looking for a simple guide for results no way near as good as this. Just an examples so you know what im talking about.
THANKS
squig hunter
Try looking for MIG pigments, they are a fine powder that you can paint on with a dry brush or use in a (for example) mud mix;) Then fix it with varnish so it doesen\'t fade away.
Squig
hckling
For an easy result, similar to that, just paint the blue similar to how you normally would, then give the whole thing a wash or two of a color similar to GW\'s scorched brown. After that, touch up with some light coats of the base color and highlights, until you reach the desired effect.
generulpoleaxe
don\'t varnish pigments once they are in place or you will destroy the effect.
either mix it into the mud mix (quite a lot) for the murky puddle bits.
or use lighter fluid to set it in place, this won\'t stop it being rubbed off but will give a little more resistance against wear.
nice one! i am practicing with some pigments (ground down pastels) and was at a loss as to how i should fix it. do you brush it on after?
