Ah, that\'s good to know. Presumably it wasn\'t cloudy and you just continued adding more right?Originally posted by Starfall
Edit: By the way, I did apply multiple thin layers, but it didn\'t work.
What is it? It\'s just possible you got a bad batch if it\'s a reliable product.Originally posted by Starfall
Edit 2: I don\'t work with bad stuff, it\'s a gel Golden Demon winner Anja Klucke also works with, so I guess it\'s my fault that it doesn\'t look like water, just in case you wanted to advise me to buy a better gel.
Orginal gepostet von Starfall
This is a product galled \"Heavy Transparent Gel - Gel Denso Brillante Gloss\". Actually a Vallejo one, No. 27591, if anybody is interested.
The description: \"Extra dense acrylic resin. Dries to a transparent finish, is used in dioramas to represent water or ice, or to create volume. For all surfaces.\"
This sounded so perfectly easy...
Einion, I think the first layer was still okay, but already the second one wasn\'t really transparent any more. The third and the following eventually were the end.
I think my layers were max. 4mm thick.
Wrong product for this. It\'s not important that someone else has done this with success, it\'s not the ideal thing to use for a couple of reasons. Acrylic mediums should really be put on in layers no more than a couple of millimetres thick (4mm is really too thick) and they are relatively soft at normal room temperature and humidity, meaning that dust can stick to the surface.Originally posted by Starfall
But this is only a mm thick... For the diorama, I need at least one inch of water!
You want clear casting resin for this sort of thing to get good results consistently.Originally posted by Starfall
...but there has to be another way?!
This is an additive for acrylic paint to increase the viscosity and to add volume, to make larger applications of paint a little cheaper.Originally posted by Starfall
I mean, the text says \"...or to create volume\". Volume sounds like a cube to me, not like a square.
