yxalitis
Haven't we all, carefully adding all the little teeth into my Blood maw, sanding and filing, test-fitting, then gluing, checking location, holding in place, waiting….Done,
Onto the next one
Done the whole lower jaw, all up ones side of the upper jaw, starting with the fifth tooth, when I thought it…”you know, I’m surprised I haven’t dropped one of these on the carpet yet…”
As soon as I said it, I knew I was done for, and yep, very next tooth, as I was placing it in the socket, the previous tooth which apparently wasn’t set, came loose, and fell into the maw, right down, deep down the throat, as far as it could go.
While I tried to pluck that out with my tweezers, the other tooth took the opportunity to scarper to places unknown, I swear it opened a portal to a mysterious land where all the dropped parts of kits go; probably called Greebladia, or something like that.
Finally got the first tooth out, then noticed the missing other tooth, so I pulled back my chair, and do the careful 1 inch-sectioned search pattern, methodically starting 2 meters away from where I sit.
Nope, gone for good…oh well, I suppose I can scratch up one tooth…GOD DAMN IT! WHERE’S THE OTHER ONE GONE???
I tell you, I put it on my table, right THERE-> IT”S GONE!
Another search was undertaken, and I found…THE FIRST TOOTH I was looking for…!
The second tooth was never found!
It’s OK, I managed to make quite a nice green tooth, and once painted. No one will ever know…
EXCEPT ME!
Onto the next one
EXCEPT ME!
