I need balls.....
Legacy Account
Help!
I need some clear spheres approx. 5-8mm diameter. I don\'t really want to bugger about casting them - is there anything else I could use? Can you get clear polymer clay? Suggestions appreciated! Ta.
Would beads work? I know you could get clear beads of that size, but I\'m not sure if you could get ones without holes through them or not. I\'ll check my local craft store today.
1st, you get sand really hot :flame: , then it melts, then you drop little drops onto (into?) molten lead to let the glass cool.
Or, try the crafts stores for beads.
Davion
Don\'t they make clear spherical beads to put in aquariums? I don\'t remember how big they are though, or if they come in perfect spheres...
Greymane
Laboratory of Dirz
5mm perfect glass balls ......
i\'ve seen them at work (when I was a Labrat) I\'ll have a look in a couple of catalogues and ask around today, they can be used to pack distillation columns.
i\'ll let you know:D
Greymane
I got balls
try these for size
catno.
DPR-530-050C 4mm balls
DPR-530-070T 6mm balls
from Fisher
They are borosilicate glass but I\'m not sure wether they are clear or ground glass surfaces ? you will get loads for the money 100\'s I think.
HTH :D:bouncy:
