archreptile
Seems everyone is airbrushing these days. I've used tamiya and GW paints thinned with X20A in the aztek airbrush for a while for basecoating with little incident (I actually thought I was getting the hang of it).
After seeing Blackadders sterling work I bought a decent infinity airbrush and decided to give it a proper go. Note I still have a pretty crappy (mainly crappy in that I cant adjust PSI, its fixed at 30 or I can use a "bleed" valve that slowly lowers the PSI but it isnt regulated) compressor.
Anyway, also got some new scale color paints and proper airbrush medium. Twas a disaster. When the brush wasnt blocking it was shooting spiders faster than anything.
Read a bit more, youtubed a bit more and aside from some recommendations to avoid vallejo with tamiya X20A (forms a gummy gunk) most people suggested water so another few sessions devoted to water thinning with the same result.
Now I understand part of the problem is the higher pressure causing spiders especially if paint is thinned too much but its just dramtically worse than what I've become used to.
Last night I had a quick session and used good old X20A again and although the results weren't great they were streets ahead of what I've been seeing with airbrush medium and water.
While I suspect that experts have little problem with whatever they use and novices battle with even the best setups, has anyone else experienced this?
One video I watched expressly forbid X20A (alcohol) as it increased drying time but I suspect that is what is actually helping me.
