I started painting when I was young, but I used to paint airplane model kits. This kits are usually painted with enamel paint instead of acrylic paint. So, when I started painting mini\'s I kept using enamel (just because I had many colors, I was used to it and had no idea that you could with acylic over plastic).
Last year, I bought the first minis for my army (the mages). For some reason, I thought that it would look good if I painted the cloak and some other parts of both mages with gloss paint.
Not long after that, I found this website and decided to take a picture to upload it.
I did not like what I saw.
So, tryed to change the mage on foot, by painting it over with matt paint. It didn\'t end up so bad. However, having a double layer of paint covered some detail:
The time came to try and fix the mounted mage... I had 2 choises: to paint it over and loose some detail or paint a way to strip it of the enamel and then repaint it.
I choose to take my chances and strip it. I used a mixture of cooking oil and paint thinner (50%-50%). I simply dip the mini in the solution for 10-15 seconds and then scrub it with a tooth brush... Dip it again and srub... And so on and on...
Finally I was able to remove 99% of the paint and I re-painted it:
It is not finished yet, but it is close. I had a lot of trouble painting the ball on the staff and the horse\'s head and the gems (I used gloss enamel there again...
Where can I find help on how to make blue gems?
BTW: I am stripping the mage on foot now...
