Just a little diorama base question...
sami2004
Hi
Im doing a diorama for my local youngbloods painting comp and was wondering what is a good thing to stick down rocks onto bases ( my base is made from cardboard :D ) and what is good to stick models actually to this rock... i havent actually tried anything yet because im in the \"early stages\" but i was thinking just superglue might do the job ???
anyway thx in advance
Sami2004
Sand Rat
Super glue, white glue/pva, gorrilla glue all work. If you can find it, Sheppard Pains book on building dioramas has a really good article on attaching rocks to things.
sami2004
Thx steelcult, ill post some pictures of it here when its done, and does pva stick models too? Because the model that will be attached to the rock is metal.
thx alot
Sami
Sand Rat
I\'d go with super glue for that one - the pva might work, but you\'re better off with super glue to attach two different substances.
frenchkid
For stiking the rock to the base I\'d say pva, because spuger glue isn\'t the best or easiest way to go for large surface. But for stiking the mini to your base I\'d say superglue, wouldn\'t want the mini to fall off.
T
t_haye2
be careful though, sinse you\'re using a cardboard base, most glues will make this warp to b*gg*ry...you\'re best off using either plastic card or a thin piece of picture frame backing..... if you\'re in the UK, hobbycraft make some excellent mdf \'coasters\' with bevelled edges, they\'re great for using as a display base. see my skaven: skaven
sami2004
hobbycraft! im sure one of those opened recently about 10 mins away from me.... Is that the place with the corny ad... if you crafty and you know it and u realy want to show it, if you crafty and you know it HOBBYCRAFT!... thx
p.s skaven dude look great
sami2004
oh yer in the skaven picture is the \"mdf \'coaster\'\" the actualy wood thing that i can see, or is there a small thin board hidden somewhere below your swamp like swamp
