Kickstarter - Anarchy Models - HS Stencils - Flexible & Reusable
Dark Severance
This campaign is shaping up nicely. A lot of nice stencil designs have been added, currently 20 different designs in this line for airbrush stencils. They are great for terrain and miniatures to help detail and do different designs. They are funded with some unlocked freebie stretch goals as well:
Kickstarter Link
Standard Designs
The size of a HS Stencil varies depending on the design, due to practicality of use, cost of production and other factors. You can click the links below to see the design examples for the stencils.
HS-01 - Hex Paving
HS-02 - Allied Stars
HS-04 - Hex Grid Small + Mini
HS-05 - Off-set Paving
HS-06 - Dragon Scales small + Mini
HS-07 - Hex grid Large + Medium
HS-08 - Dragon Scales Large + Medium
HS-09 - Steampunk Gears
HS-10 - Dungeon Creator - 30mm square block paving
HS-11 - Dungeon Creator - 25mm square block paving
HS-12 - Flamestorm
HS-13 - 25mm/1inch Squares Stencil Set
HS-14 - Tank Turret Numbers.
HS-15 - Vehicle Detailing - 1 (video in Update 11)
HS-16 - Creature Features 1 - Mottled (pics in update 12)
HS-17 - Deadzone Battle Grid (for use with Mantic's Deadzone)
HS-18 - Balkenkreuz Set
HS-19 - 93mm Battle Grid - (suitable for Dust Tactics)
HS-20 - Sci-fi Corridor Game Creator - 30mm squares (works similar to the Dungeon creators)
Freebies:
- A5 sheet of blank HS stencil Material.
- A5 sheeet blank HD (thin) stencil Material.
- Half sheets from their previous HS Stencil line.
- Two different styles of air vents
- Radioactive symbol and fallout shelter stencil
- Airplane, Tank and Roman numericals
4 of the newest designs added:
- HS-17 - Deadzone Battle Grid (for use with Mantic's Deadzone)
- HS-18 - Balkenkreuz Set
- HS-19 - 93mm Battle Grid - (suitable for Dust Tactics)
- HS-20 - Sci-fi Corridor Game Creator - 30mm squares (works similar to the Dungeon creators, see the video for HS-10 on the main page)
