I long ago got out of the habit of handling models while painting them, it was just too easy to rub paint off textures or edges. Since everything is pinned anyway I just use pin vices most of the time to manipulate things. I\'ll be using Shawn\'s
Quit touching your mini!!!! cork trick soon though for minis that are small enough.
I like to use glove when handing figures for assembling, basing etc. (if this is after painting) but I use the vinyl type - very much tougher than latex, you can usually get a dozen or more wears out of them before you get any tears. Nitrile are the Rolls Royce of the \'rubber\' glove though, definitely the one to wear if you\'re dealing with organic solvents.
Originally posted by vincegamer
I used to use the latex glove too. The problem I had is it has greater friction (probably because no oils) and had a greater tendency to damage the paint if I touched painted areas.
I found the exact opposite! Plus much less shiny spots (big problem for me as I don\'t like to clear coat).
