Making a force sword in 0.2 seconds (beginner and bored only)
Tony Manero
First of all, we start to choose a base colour, for example Regal Blue.
Water it pretty much till is 80/20 water/colour.
Pass it on all the blade
Now, when the colour is still liquid, choose a final colour, for example Skull White, water down it a little and pass it roughly on the edge of the blade. Let rest a second the mixing and see how the colours combine themselves
now take a small amount of almost unwatered Skull White and make small dots on the very edge, mixing the borders of the dots with circular movements...
Let the colours dry... tadaaan :D you have a cool force sword without the boring lightnings....
Ogrebane
This is a great way for doing ant magic weapon. i will give it a go. Thanx tony. PS hows the Dread going.
Ogrebane
Yer I saw the WIPS just waiting for the finished product. Its going to be a sweet looking army when its done.
Ogrebane
All things in there own time. And I think its time for another beer.
Seriously its worth the time your taking on it for what you are producing. Is this army your own or a commission. I cant remember it was too many posts ago
Shawn R. L.
Here\'s a watercolor trick. Using a light background, water down a color and put it on. Then lightly sprinkle the area with a touch of salt. In an hour or so check out the result. PSYCHEDELIC....
cookster
ima try that rl shawn. I think that doing what Tony suggested in section letting it dry then doing another part would be good.
Shawn R. L.
The salt trick works great on paper. I\'m not sure how good it would work on something as small as a mini. Never tried it.
Ogrebane
Tried the force sword thing on a base that represents water. Worked perfect. After 3 coats of fake water and it took 2 mins tops. Now I will have to try the salt trick.
Ogrebane
You should put this in the articles section. Cause in 3 mionths when a few more brain cells have died I wont be able to find this post
