TheRedGod
Two Questions
-a melee attack allows a unit to change facing then shift to align. Can a unit shift without changing its facing to face the attacker?
-shifting can be done as part of a melee attack. Can shifting from other abilities (such as order tokens from Varys or Wendamyr) be done in melee (staying engaged), so as to make space for another combat unit to charge in on that facing, or to shift to 100%?
Source: Pg 15
"When a unit performs a Melee Attack, and it is engaged withonly 1 enemy unit, it may first choose to change its facing sothat it is facing said enemy head-on (in the case of an enemy beingin its Flank or Rear). A unit engaged from multiple sides may notchange its facing. The enemy has prevented them from doingso! The unit may then choose to shift its tray so that its trayis 100% aligned center-to-center with its enemy, or chooseto move so that their trays are only 50% aligned (as to allowanother friendly unit to later engage that enemy in that same Arc)."
Source: Pg 15
