Mixing gw paints (how do you do it)
Dedwrekka
I\'ve been told too many times to use a 25/75 mix or a drop, of GW paints and I don\'t know how to mix it. The gw paint pots don\'t seem to be made for pouring. I\'d just like some help on how to mix paints properly from the painting gods here on the forum.
*bows and then shuffles away slowly from the forums*
GunjiNoKanrei
Don\'t, just use Vallejos ;)
Seriously though, you can use a pipette to measure the correct amounts. Or pick some paint up with a toothpick and count drops.
T
Tiderius
Or you could use droppers that you can get at a pharmacy. I can get pretty exact amounts with mine. And the glass one clean really well so you can just clean them and use new colors when you need.
KatieG
Yeah I typically use toothpicks to get the paint out of the pot and onto my pallette as well. Then I stick some water next to it, and pull it into the paint until I get the consistency I want... you could also just measure the water by eye to see what fraction of the paint puddle it is if you get my meaning... I use a container that I can just dropper water from, but you could also just use an eyedropper or something like that for the water (I don\'t use it for paint because I find it too messy).
--Katie G.
T
Tiderius
Yes, the one piece eyedroppers are horrible for paint. But if you can get a two piece eyedropper (especially one wiht a scale on it) it works perfect.
The top comes off and you can just rinse out the glass tube.
I use old GW Standard brushes with which I make a small puddle of water on the pallette and then to take the paint from the pot to the pallette. Washing the brush out in between colours.
I find that this helps me to measure the levels of colour when mixing and I\'m able to keep a close consistency for continuing colours.
I use good brushes for the actual painting of course.
Trevor
Brushlicker and Freak!
I just chuck blobs of paint together, keeping on adding until I have the right colour/consistency (oddly inaccurate for a scientist, but then this is my creative streak showing itself)
This does mean that I sometimes make up piles of paint, trying to get the right colour.
Your post could mean one of two things. If you are talking about an every day mix - say for a highlight color then:
ya . . I use old brushes or sometimes the heel of my own brush to mix up stuff. I rarely get caught up in percentages - it\'s all done by guessing, eyeballing, whatever.
My only problem with the eye dropper thing is:
1) I don\'t need anything more I have to clean. I usually paint for several hours at a time and use up to 50 different colors in a session. If I had to clean a dropper between each one I\'d go nuts - even cleaning once is too much. And
2) a drop is not always a drop. A drop of thin paint is not the equivelent of a drop of a thick one. And how do you measure the difference? Apply some viscosity test? To get it chmically equivelent is a huge waste of time as paint even in the bottle is inconsistent to it\'s neghbors and also changes over time. GW usually requires some water every time. Some Vallejo\'s do as well - some don\'t. And the next time I sit down some seem identical - some are worse.
Typically I take one brush of stuff - put it on the pallette wipe it clean - get a drop of the other color, apply it to the palette and finally a drop of water. As I add highlights I wipe the brush (not with water) and add more of the lighter color and mix that in . . .
Part II
But if you are mixing up a whole bottle of new paint then:
I defer to the others - I think I would try pouring anyway - adding water to make it pourable or of it\'s thick as GW can be then using a brush to guide it. Sounds messy.
Actually I am tired of mixing up a really dark gray but I think I will buy the Vallejo Game color Black and and some white and just squeeze them into a new bottle until I get the right shade . . .
T
t_haye2
Yep, that\'s my \'pro\' technique as well. Just grab an old brush and blob your paints together, none of this precise measurement malarky...:D
Cerridwyn1st
Dragonsreach suggested I try Windsor & Newton\'s Payne\'s Grey for a dark gray. It is so dark it\'s almost black. You might try that, too. I thinned mine with water and Magic Wash, but water alone would be good, too.
For moving paint to my pallet, I use these little plastic dental tooth picks. They have a little bend on the end so they work like tiny pallet knives. Great not only to move the paint but mix it as well.
MDL
one of the best tools out there...
tamiya paint stirrers: check these out...
http://www.hobbylinc.com/htm/tam/tam74017.htm
Perhaps one of the best tools on my bench. Little spoon on one end, a flat blade at the other. Excellent, is all I can say, esp. when spooning up on a wet pallete.
kittykat23uk
Same here, I usually just do it by eye as well..
Regards
Kat
