More Photoshop Help!
MarkusTay
I need a way to repeat using the same objects over and over, like creating a new custom tool.
I\'m new to photoshop, and I\'ve been using it to do some fantasy mapping. I\'ve seen some cool things from Spacemunkie, and I know AlexiZ posted at least one photoshopped pic that was beyond my meager skills, so any help from the gurus would be great.
Two questions to any of you photoshop pros out there- is there a way to save more then one object to the clipboard (without purchasing a plug-in), and even better is there a way to make frequently used objects into a \'stamp\'? I find myself copying and pasting the exact same objects over and over, and it\'s getting VERY tedious.
Unfortunately, the current project I am working on is 90% done, and I now know enough to have done a MUCH better job. That pattern maker tool is the bomb!
So rather then scrap what I have done, I\'m going to finish it for posterity, and then start on a bigger better version.
Also, if you know of any decent tutorial sites out there that would help. I\'ve found a couple but most seem to assume you know some stuff already, so when they say things like \"Its best to work in layers\" I have NO clue what they are talking about.
One other thing while I am at it, are there any good FREE file hosting services out there?
Thanx in advance - Mark
Legacy Account
Of course there is :D
Select the object/image/whatever you want to repeat. Select the \'Pattern Stamp\' tool - it\'s clustered in with the \'Clone Stamp\' tool on the toolbox.
Go to Edit > Define Pattern. Call it whatever you like. Click on the little thumbnail pattern box on the Option Bar at the top of the screen (only visible with the Pattern Stamp tool selected...).
Select your pattern and start painting!
Hope that\'s what you were looking for. You can use the Clone Tool if you\'re wanting to blend stuff together....
