Movement +/-
Daimyo79
JUst wanted to check that we are playing the movement rules correctly..
eg If Jon Snow's unit is affected by the " for the watch " and takes the +2" movement bonus this is added to the unit's basic movement value rather than just adding 2" to the total move ?
Whereas the 1" deduction for " rough " ground seems to be just 1" off the total move ?
PinkFoam
If the effect increases your movement stat then you would increase the value rather than simply increasing distance moved. If the movement stat is being effecting then the ability text will include the speed icon (green background with yellow foot). The key difference is that when marching, an ability that granted you +2" of movement would only cause you to march the specified 2" extra while a +2 speed bonus would cause you to march 4". You are correct with your interpretation of rough terrain features.
