Hi,
Ive been trying to think of a way to base my Empire Army. I have decided to do a wet, sloppy trampled muddy battleground look. I know there is a \"mud\" tutorial here but it seems to be a dusty dry look, I am looking for a wet soggy look.
i suggest making a slurry of glue with some flock (the more glue the more gooy it will come out, and the more layers you will need to out down on the base). slather it on the base , let it cure, and paint it. gloss varnish helps with mud/slime too.
i tend to use either putty or filler and then paint it the appropriate browns (or probably not as i am colour blind!!). then add a bit o gloss varnish after dull coating the mini. bear in mind that when adding mud to the bottom of trousers, robes etc, the mud is darker at the bottom where it it wetter:
