Hi Horde, I see you have a Smiley next to your last post so may differ but I had the Thumbs Down affliction for a bit, if I remember rightly I had to enable a blocked script on the page.
The mini looks to be coming on nicely, an action filled sculpt that should look suitably scary/horrific once complete. Are you thinning your paints from layer 1? If so I'd suggest less dilution on the base layers (particularly with paints with white in them like pink fleshtones) for smoother application. Then thin further for layering/blending in highlights & shades. It's a bit quicker too! Oh, and catch that blob of white on his forearm while you still have the skin paints out (or is that putty, it looks very thick, might just chip off)
Cheers, B.
PS you see where on your Imageshack page there's the links on the right, copy the direct one & stick it between image tags, where I've left a space...
...should do the trick
Play around in your next post, you can always edit it!
