My first minis.
exe000
Hello!
I\'v published my first 4 minis. I would be thankfull of any comments and advices:duh: I need to collect as many informations about technique as possible.
The links:
http://www.coolminiornot.com/109700
http://www.coolminiornot.com/109780
Thanks.
DrEvilmonki
Welcome to the madness.
Are those the first four minis you\'ev posted or painted? They are pretty good for starters. Thinning your paint a bit more will help give the details a bit more crispness.
If you are after painting tips start a figure and put it in the WIP thread. Ask as you paint; see how that goes. Also read the articles many excellent pointers there.
Enjoy
Check out the photography page as well there are sound excellent threads on how to improve your pictures. :D
Shawn R. L.
Nice bases and color choices. The tendancy when starting can be to go very bright with all the colors. You have showed good restraint and used the really bright colors sparingly. That makes the bright\'s stand out all the more. Keep up the good work, keep posting for critisim.
exe000
Thanks for comments and advices, yes they are my first painted minis. Before painting i tried to read as much as i could about it, and that helps a lot.
Stuntylover
The fact you did your homework before you started painting shows. You have already reached above the tabletop level and you are using techniques beginners don\'t normally use until after they are told to read the manuals. However, the bases on the plaguebearers are dreadful. Had you finished them better your CMON score would have been higher. Well done.
Naukhel
I agree with stunty. Doing the reading first definitely makes a difference.
Very nice first showings, and looking forward to seeing you improve as you do more.
