My First Squad = Black Reach Terminators
phreak0
number one is the same everyone tells me, photos need to be better.
i would recomend browsing through the article section here, there are alot of really great tips and tricks there. what i would work on would be brushcontrol since they look a bit sloppy (i dont know how to express myself softly in english, im swedish). i dont know for how long youve been painting but this is definitely a start.
ok photos are shit and i can't see bugger all!! but one thing does jump out.........drill your bolter barrels!!!!! then post new pics and we shall tear them apart!! (if you want)
Farin
photo is big enough when i click on it, but for the future: use a uniform background, it will help.
that´s your forst squad, so of cause there are something to improve:
first of all: yep, unfortunatley they are a bit sloppy ( not meant as an offense, honestly ), since i can see red color where it shouldn´t be.
Next time , take your time, it´s not a race. drill your barrels. read the artcle section.
For starters i would highly recommend you concentrate on clean painting and solid base colors ( yours look uneven ). Once you get that try basic highlighting and shading. No Dry brushing , though - that technique is just messy and won´t improve your painting.
Also , white and red aren´t easy colors to paint - ask anyone.
You might wanna use the new GW foundation clors, they´re great for flat base colors.
ok i hope that´s helpful
:bye:
:bye:
balls i keep forgetting about that!!
ignore me.....
another thing to add to the bolter barrel thing is make sure all mould lines are removed!!
personally i would start off with an even base coat of each colour. as mentioned gw foundations are good, as are p3. i dont paint space marines although i do have the new space hulk so i am thinking of painting them up quicky. currently my plan is:
1 prime (ie proper halfords primer, not a crappy spray paint that rubs off as easily as normal pain like gw...)
2 undercoat the main colour (red in my case). i shall be using p3 sprayed through my nice new airbrush for speed (a couple of thin coats should have it done quickly and smoothly)
3 quick zenithal highlighting with the airbrush and a lighter red
4 some edge highlighting
5 wash for shading
6 details
7 gore/weathering
depending on the time you want to spend on it, you can water your paints down further to build up slower and there fore smoother highlights.
it's always a trade off between smoothness/neatness and time
