Natasha- 200mm Pegaso Resin Kit
Tanker
This is my first WIP on CMON and thought I would throw it up since its a big kit. As some of you may have noticed, I like doing the larger stuff like this and is the biggist one I have done to date. Still have a 90mm Andrea and 72mm Reaper to finish this weekend before I really get into working on her to much.
At this point I have her all pinned except the base which I will do later and most of the gap filling done. Still have a bit of clean up on her to do as well.
Placed a standard 28mm next to her for scale refrence.
Any suggestions on colors would be appreciated, right now leaning towards the way she is painted by the manufacturer, the marshals jacket keeps throwing me, would like to do it in black, just not sure how it would look.
Any comments and help appreciated,
Thanks :D
Link containes nudity
Natasha
Tanker
A little bit of an update here. This is more for concept art so you can see where I\'m going with her. This represents quiet a bit of work all ready though. Figure since the casting was so bad I spent mayby 4-5 hours on clean up and pinning everything. Then getting the smooth base for the skin took about another 3-4. Once again the problem with following up with oils is the base needs to be as smooth as possible or it will show up really bad once I start with them. This had a pretty rough suface and alot of pits even after I took the dremel to it.
Decided to go with the purple/ black look for her instead of the standard cover art. This is by no means close to cleaned up or anything, just giving you an idea of what she will look like. Think I\'ll go with a dark brown/black for the gloves and boots. If not still leaning towords the purple for her boots at least. Ideas or suggestions?
She is going to be a light blond as well with a lighter skin tone leaning on a pinkish side for the shadows I think. The leather is going to be patent with a shine on the corset and the boots.
Thanks for looking and comments welcome
Had a problem with the link, just use the above posted one, has the update on it.
