To avoid the chalky look you must thin the paint and DON\'T do dry brushing.
To paint my elves\' faces I do the following steps (the same would work for other faces, just change de colours)
1. Basecoat (at least in the face) is always white
2. Paint the face with Elf Flesh
3. Washing with Chesnut Ink. In very dark areas (mouth, eyes and so) I put the ink with almost no water.
4. The mini has get darker, so I re-paint with Elf Flesh
5. I mix Elf Flesh with Skull White. 2 or 3 different colors. Paint hightlights with these without using dry brushing
6. Final hightlights with Skull White.
As you can see, many layers of colors are used. So, to THIN the paints is a must.
Hope that helps
