Step by step part 1: Shading
Ok here is the shading for the second rider. Sorry if the pics are washed out I have to correct that when I do the highlighting, not sure what happened... The highlights will be in my next post.
This first picture just shows the base coat which is a mix of 50/50 catachan green and camo green.
Once the base coat is done I then picked out areas that I wanted to have a darker look and base coated these areas with pure catachan green. I do this because it adds a nice aesthetic to the mini. Arrows indicate some of the areas I did this to.
This next picture starts the general shading with pure catachan green. Areas that are less exposed to light from above and in some small cases areas that will help add some interest to the mini. About 2 parts water to one part paint. I also added a drop of brush on sealer from reaper as I find it helps keep the paint where I want it. If I do not do this the paint will look too streaky.
I then shade with pure dark angels green. The mix is the same as the catachan meaning 2 parts water, 1 part paint, 1 drop brush on sealer. I highlighted the areas that I base coated with pure catachan the most since they will be much darker than other areas. The gauntlet shows off the shading the best I think.
I then shaded with previous mix with a little liche purple added to it. Always trying to work deeper in the recesses and making sure that some of the previous shaded layers are showing through. I also just work the color until I reach an opaqueness that I am satisfied with.
The last shade is that last mix with a little bit of black added. Again painted until I am satisfied with how it looks and also painted in a smaller area than the previous mix.
Now that the shading is finished I will clean up some areas with the base coat that were hit by the shading that I did not mean to hit, like the upper calves. If you have any questions let me know.
Highlighting coming soon
