orc arm!
BanJo
hey, i am going to have my orc nob rest his axe on his shoulder. i have got two arms, but im not sure where to cut to get the right angle, and not loose to much of the arm. if you have seen allan c\'s orc nob bionic, thats the look i am going for. which one would be easier to use?
here are the pic of the arms.
thanks for all help :)
Torstein
Shawn R. L.
I would cut it at a 45 degree angle at the elbow then file away enough on the inside of the arm to get the right angle. after gluing it in place use GS to make the muscles squish outward and up toward the shoulder a bit.
Hi Torstein, I would use the right one, the biceps muscle looks like it\'s already flexed correctly and you won\'t lose the gun.
Saw a V-shaped notch from the inside of the elbow, leaving only a small amount of metal near the elbow bone, then bend the arm closer together. To get the angle of the hand to line up with the shoulder correctly you might also consider cutting a notch from the top of the wrist too, the forearm armour should help hide this cut. As Shawn says then smooth out the joins with putty, remembering that there\'s a bulge of tissue when you bend your arm tightly (pose in the mirror to see how it looks for yourself).
