Paint comparison tool
Arma
Just saw this posted over at TGN.
http://colors.silicon-dragons.com/full_line.php
It\'s a tool for comparing different lines of paint to get matching colours.. VERY nice. :innocent:
Roger Bunting
I\'m not sure how accurate that is. Some of the colours on the screen don\'t look like they are in the pots, at least on my screen. Also, comparing GW to P3, why hasn\'t sanguin base or highlight been mentioned as a comparison to the GW reds?
Arma
I suspect it works by comparing HTML hex codes for colours... either way, it\'s a good start imo...
TAB Studio
Thanks Arma
In the information he asks for paint companies to send true colors and he explains how he set the program up as well.
All in all very useful for me, even just to see the range Thanks Arma
Here is a color selection program that is pretty cool in exchange, you can get a desktop version.
Kruler
Joe Kutz
Don\'t worry too much about the on screen display - that doesn\'t actually tell you much of anything unless you have calibrated your monitor to the same output that I have calibrated the scanning equipment to. If you want to do that though, it is calibrated to FujiChrome IT8.
Nope, I use sRGB as the starting point. The actual comparisons are performed using CIE Lab color space formulas for mixed media formats. It is effectively the same method used at the big paint companies (Sherwin Williams, Valspar, Dutch Boy...) in order to handle paint matching at the factories as well as the machines that paint stores use to match color samples that people bring in.
There are a lot of different variables that will effect the end paint sample used. If you have a few that you suspect are wrong, let me know. The FAQ does explain things a bit more.
When I have ones that I know need to be corrected, I order up three of the pots from different suppliers (hopefully getting paint from different batches in the process) and take new samples averaging those three together.
Anywho, if you have any problems with the colors - let me know. I can\'t fix what I don\'t know is broken.
Roger Bunting
Thanks for the info. Without the calibration of my monitor to match your scans, I\'m not sure how much some of the colours are affected. I haven\'t done comparisons myself, I was just thinking that on my screen GWs Red Gore looks more brown-red than the paint is. That could be down to my monitor.
It is a useful tool, though, Thanks for the work on it.
