Show Case Studio
can anyone please tell me any good ways to paint stuble and shaved heads, or are there anygood links for me to get help with this,
Except..........mines white now.I'd recommend being very careful using blue for this. Blueing will happen anyway if you add black (or a simple grey) into the flesh colour, no need to actually have any blue in the mix; with blue present it could easily shift the colour too far in that direction - it should look blue, not be blue.
As is probably obvious, tattoo colour is something that can be approached very similarly and here you do sometimes want to use blue because tattoos can become blue (very dull blue) over time. Beard shadow on the other hand generally only looks blue.
Cooler *gack*
That referred only to the ones that look blue, i.e. very dark brown and black hair. Obviously completely different for lighter hair colours. Very blond men have very little in the way of visible shave-shadow, particularly on the face when they're younger (light hair + sparse growth).Dragonsreach said:Except..........mines white now.
Right on. Amazing how infrequently this is taken into account - even the hairline tends to be very generic or standard, very little in the way of M-heads (widow's peak) or male-pattern baldness even on historical miniatures.Dragonsreach said:It's alright painting someone young with a full head hair shadow line, but if you take the Hasslefree Wolf figure that's a man well in his 30's. It'd be appropriate to have a receeded hairline or even a "Hole in the Haircut" showing in the shaved head.
This does yield a blue - nearly all black + white mixtures give dull blues.Pygmalion said:I second this. In classical painting you can get an effect the eye thinks of as blue with a simple mix of black and white...
Another approach is to make the beard color cooler by adding in a blue grey to your flesh mix. Apply the mix in very thin filters, it won't take many passes to create the effect.
