painting flames
Sakura
Hi there,
does anyone know how to paint realistic flames? I don\'t realy know how to beginn or how to get that glow.
Any ideas are appreciated!
Smoth
start white
go to yellow
then orange
then red.
The center is the brightest. start with white. You should ONLY do the red on the farthest part of the flame.
T
t_haye2
yep, the tips of flame is always the darkest, try to remember that, otherwise it\'s going to look weird. I actually go all the way to black at the very tip, I like it more that way. So, white at the base, working through yellow, orange,red and black at the very tips.
Greymane
Alchemy
It also depends on the chemistry (or magic). The principles laid down above are all correct for most organic flames that we see apart from gas, white to blue spectras (due to complete combustion ). Copper will give greens to a flame, sodium reds (you can try that with a gas hob and salt - flick salt into the flame ). There are more but my chemistry and memory don\'t extend to them today.
Mind you the classic white orange red black (black being carbon from incomplete combustion combustion look carefully at most candle flame tips) seem to work best as it is instantly recognisable as flames, green might not be. ???
Sakura
Okey, thanks, I understand what colours to use now, but how do I manage to it, that they look as if they would glow or shine... well whatever flames do.
nadine
http://www.coolminiornot.com/index.php?id=22939&c=All&m=All&nm=none
That might help :) A picture is worth a thousand words and all that jazz.
Dimiotrix
im currently doing blue flames on my tzeentch lord i have found myself using 12 different shades of blue and wet blending them together to get it to look right. With normal flames start with a white then go to a yellow then orange and then red. Make sure you have alot of inbetween colors too so its blended very smoothly.
kittykat23uk
While we\'re on the subject of painting flames
I\'m working on the FW fire dragon and I\'m trying to go for a flickering flame look to his body and wings. My concept is that he\'s in a cave and there are hopefully going to be some areas of flame that I want reflected onto his body. I\'d like to try and incorporate the French painting style, the depth of colour they seem to be able to achieve using complimentary colours and really good blending. However, most of the best French minis seem to use a lot of earth tones- coppers, greens, greys, silvers and browns. I haven\'t seen an example where the mini has used hot colours such as yellows, oranges and reds.
I\'m not entirely sure how to go about this. Anyone got any good ideas? ???
Regards
Kat
