painting the sexy eldar
mantastyle
Hi all yall cool knowledgeable gamers out there! I'm an avid 40k player and I need your help! I've been collecting eldar for many a long year but never truly settled on a paint scheme. But now is the time! So far this is what I am thinking: primary color is lich purple with possibly some warlock purple highlights. But, what then? Codex or fortress gray wouldn't be bad for a tertiary color although not really noticeable. I've been told that colors opposite each other on the color wheel look good and stand out so possibly some yellow flames? I can't decide. what is your opinion almighty gaming community?
mantastyle
Thank you for your lovely comments! I've been looking and posting on several forums such as this and gotten some good advice in addition to this picture!:
http://www.coolminiornot.com/index/whatc/SF/whatm/GW/id/121896
This is exactly what i'm looking for! I think thats base coat liche puple with warlock purple hightlights and a slight touch of skull white on the very edges of the armor. Am I right in that assumption and if so, how in the world do I learn to get that precision? Help plz!
This is exactly what i'm looking for!.., how in the world do I learn to get that precision? Help plz!
That style of highlighting often gets refered to as edgelining.
Basically take a brush in very good conditon and with thin paint run its side along the edge of the raised section, voila! sharp highlights on the edges.
Takes a little practise to get the best effects, but can look very good if used on a whole army.
Tanasis
Actually, I think there are 3 layers of purple an that miniature (dark-midtone-light). It might be more satisfying this way.
Jericho
Consummate Brushlicker
I don't see a white edge hilight anywhere but there's definitely something along the lines of the old Tentacle Pink for the final edge. I'd say you're likely looking at 4 colors total once you include the shading.
I don't know of a color dark enough for that base coat so you'd probably be looking at a mix of Liche and black, followed by Liche, then Warlock and finally Tentacle Pink. From experience, a 50/50 Liche and Warlock mix is a good idea to ensure you get solid coverage and slightly smoother blends. Warlock doesn't cover super well.
Anyway you could probably streamline that a little bit if you want, I'm sure the colors will work out well since I have used a virtually identical scheme in the past for doing up some Dark Elves and it's a good one.
