Originally posted by DeerHeart
I use paper-clips that I cut up with wire cutters for pinning minis. They are cheap and come in a variety of sizes.
My question is for anyone who uses a rotary tool (Dremel) for pinning; Does the drill bit ever get stuck in the metal while you\'re drilling it? This happens to me regularly, and once I lost hold of a piece and it shot across the room. Fortunetly no major damage. I\'ve tried swiveling the bit around while I drill, and that has helped some. Any suggestions?
I\'m new here, but this is something I do know about!
Drill bits in the Dremel really don\'t work real well unless they are the good quality ones. The cheap bits that come with Pin Vises and in the cheap index\'s are a little rough, which comined with the speed of the Dremel will either cause the bit to stick or they can even get hot enough to melt the metal( and they will melt plastic!). You can get good ones at any machine supply shop, and they are realativly cheap.
You should work the bit in and out like previously stated to keep the chips cleaned out of the hole.
I personally prefer to use a burr that is just a little larger than the pin I\'m going to use ( helps with alignment later ) and run it at the lowest speed. Once you have the hole started, just work it in and out like you would with the drill until you have the depth you want.
And always use a vise if possible, or at the very least use pliers to hold the part. I use Hemo\'s that I bough for holding mini\'s while painting, and since they lock they work great for holding things while drilling and filling.
What your fingers, and wear some glasses/ googles when ever working with a Dremel! Those small bits can break easlly!
Hope this helps
