Please help with NMM gold
MClimbin
Hey all,
Check out this cool bone armour and spearhead that I painted!
Unfortunately, I was going for NMM gold. After 2.5 hours of painting back and forth, I really need some help getting this to look even a little like metal. Anyone have some time to give a little advice?
Edit: Thanks for the advice about ImageShack!
Click image for larger pic
Legacy Account
Your pic isn\'t working.
A solid recipe for NMM gold is black, Cobra/Snakebite Leather and White.
Start with a black/leather mix.
Highlight with leather.
Further highlights with white/leather mix.
Spot highlights with pure white (I like Ivory White...)
HTH;)
Mosch
Your picture seems to be uploaded to a Yahoo Group which we can\'t access if we aren\'t members. Try another hosting service (for example http://www.imageshack.us ), that should increase your luck ;)
MClimbin
Thanks for the pics Shawn, I\'ll study those carefully.
Having some problems with ImageShack now, hopefully this one will work (see original post).
Mc
calabdark
do my gold nmm in the following way, firstly basecoat the gold part with scorched brown, then start layering/blending up with snakebite leather, followed by sunburst yellw/ white mix 50/50, final highlights add more white to the sunburst/white mix, where i felt the transitions werent as smooth as i wanted i mixed some in between colours , an example of a mini i did this way is here
http://www.coolminiornot.com/95342
hope this is helpful
P
provoke_me
the few times ive done NMM gold ive used the same recipe as spacemunkie. its alot easier then using milloions of colors and pulls it off rather nicely.
frenchkid
by the look of your pic it looks ok.
Things to keep in mind about metals is that they have a strong acceleration of light, and very high contrast. The best thing you could do is have a look at some good NMM. AlexiZ does some great gold NMM, and I belive the receipe spacemonkey as given you is the one she uses too.
MClimbin
Thanks again. I posted the final result (I guess that is overly redundant) here:
Dark Elf Beast Master: 95556
After getting your feedback I went back and increased both the dark and light spots, to try to get a more rapid transition. Dang, that was tough! It helped to look at AlexiZ\'s photos too (after I pulled myself out of my deep depression from comparing mine to hers). ;)
Anyway, it looks better I think, thanks to you guys and I\'ll keep working on it.
A
Alexi_Z
Yes... For gold NMM I using same colours: Chaos Black, Snakebite Leather and Skull White...
But this is not important... :)
The more important thing is right highliting and shading... Metals with relief has many reflections and highlights... If you know how it must be - no matter what colours you take...
Take a look at Hajime Sorayama works for inspiration: http://www.picsnovas.com/chardonnay/hajanima1.htm
