Primer
AegisFang
Hello everyone! I\'m searching for a new primer company anyone got any sugestions?
Any help will be much appreciated.
AegisFang
Nelson
Hmm....what were you using before? I\'m using GW right now, and I\'ve had absolutely no problems with it.
AegisFang
My problem is that red doesn\'t seem to stay on my primer specially black primer so I was thinking it might be the primer? It lives streaks showing the black under it.
Astonia
Hm, Red on a black surface is very hard to do, I know cause I\'ve been trying for hours now to get a decent red colour on my black primed cold one. Try thinning your paint with water and paint several layers instead of one, or you can try to paint the mini in another colour first (brown maybe, I know that works for yellow) and then paint the red over that. That should do the trick :)
But really, if you want to paint a lot of red, use white primer (and lots of thin layers).
Nelson
Yeah, Astonia\'s right, in that it probably isn\'t your primer so much as the paint itself. Reds are generally low on pigments or something (don\'t really know) but basically it means that they\'re generally hard to cover with. Around three thin layers usually does it, though.
AegisFang
Thanks alot guys! I\'m working on a raider for my wych squad and is fading from black to red. So I primed it black thinking it would make it easier but I gues I should have gone with white primer.
finn17
Grrrr...ed
Red is tricky, but there are two tips I can think of that mght help.
1) If you are going to undercoat black then paint the red areas with something like GW\'s \'Smelly Primer\' first - a couple of thin layers.
or
2) Undercoat white, then give the whole thing a black wash in either very thin paint or black ink. This should settle in the crevices and provide shading later.
I also like to wipe the mini over with a rag before the black has dried to remove as much as possible from the raised surfaces
Trevor
Brushlicker and Freak!
I generally like going from black, even with things like red.
However for yellow you really need white.
What Finn suggests is a great way of getting the dark shadows and easier coverage.
mickc22
Granddad!
I have never had problems painting red over a black undercoat, just cause it involves a bit more work building up to the desired intensity, that isn\'t a \"problem\" it\'s learning a different technique
(that isn\'t having a dig at anyone just an observation, no offence meant)
having said that, a red/brown would be a suitable base ie vermin, maybe with bit of red gore in it :D
mickc22
Granddad!
try snakebite or leprous or anything with a similar tone, ie a yellow/brown, mustard kinda color
Cerridwyn1st
red/brown base coat...
Regardless of my primer (white or black), I use a base coat of 50/50 VMC Hull Red and Red. I never have problems with streaking when I paint on top of this mix.
Maybe your primer is too slick? I have problems as you discribes sometimes with Tamiya Fine Primer (it is a white primer). If the first layer of paint is too thin, it will shimmy around on the surface of the mini and not stick.
