Redfinger's WIP thread, Mechs and more!!!
Redfinger
I am going to start a new thread that has the correct title, a re-hash of what I have already posted, but scroll to the bottom and you will see some new stuff!!
Been working on this big guy, her is 1/35 scale but could be used in Infinity and 40k. I have all the major assembly done, and I am getting ready for primer and paint next.
I have more images and a brief review of the model itself on my blog, feel free to check it out and thanks for looking!!
http://redmodeling.blogspot.com/
Update;
So I am back with part 2 of this wip. I have gotten quite a bit done since the last post, but I failed to document it, because it was basic paint and weathering stuff that I have covered before, or will be covering in future posts on other projects. With this project I would like to focus on using oils to weather and enhance the surface of the model, I will be demonstrating 3 specific uses, how to use oils to discolor a surface, how to use oils to create panel variation and how to use oils to create weathered effects. That will all come in my part 3 of my WIP, but for now I just wanted to show some pics of where the project is currently at. I have always been a fan of the Naval Aviators known as the "Jolly Rogers", perhaps one day I will pick up a F-14 or F-18 and paint it up in those colors. For now though I felt like using that scheme to influence how this mech is going to look. I sourced some skull and cross bones decals and busted out my paints, airbrush and masking tape and went to work.
Here is the result so far.
A quick rundown of the colors used for the base coat was a 50/50 mix of VMC Neutral Grey and VMC Off White. I also through in a drop or two of VMC Blue Grey, and VMC Flat Earth. The end result is a color that is a little more blue than I would have liked, but I like the final result so far. When I bust out my oil paints I can modulate the color a bit then. Anyway my custom color was applied over a dark grey automotive "etching" primer. I find this product is great for use with resin and it creates a really nice, durable surface that paint will adhere to easily.
The grey color was applied via airbrush over the primer is a random pattern, basically I airbrush a lot of squiggles over and over an area and slowly build the color up. This results in a finish that has varied amounts of the dark grey primer showing underneath. I will be doing a tutorial of this on future projects to better describe the process. In this picture that I posted I have a 1/35 scale figure I have been working on to provide a sense of scale.
After I got my base layer painted I went in and started to add in my paint chipping, and some alternate colors. The yellow areas were masked off then taped and the white areas were hand painted. I really wanted this model to heavy a heavy used "urban" look. When I go in with my oils I will not be doing a lot of rust, probably just more grime and what not.
After the paint of course came the decals. Here is a close up of some "fiberglass" decal that I added on the front nose area. I think it kind of gives the model a ED-209 look. I am kinda of thinking this is more or less some kind of optic or sensor array that allows the pilot to obtain a virtual image of the world outside the cockpit. You can also see the Jolly Roger I added as well as some decals along the left side of the image that actually have a pilot name there.
Finally here are a few images of some of the weaponry. The rounds on the belt feed are not completed yet, as are some of the other details as well. This is because of the weathering I will be doing, some details will need to be cleaned up after the fact anyways. Next post will be the oils and the process that is involved in using those!!
Update:
So I have decided to use this thread as a place to log my progress on my projects. I will be making a few back to back posts here showing what I am working on. I have not updated this project for a while, but I have gotten a lot of oil weathering done. Here is where it is at, along with comments on how I did it.
To start with here is an image of the model I am working with and the supplies I am using. You will need a paper towel, brushes, Odorless Mineral Spirits, mixing cups, a palette and of course your paints. I picked 3 specific colors for this part of the process, Yellow Ocher, Dark Rust, and Starship Filth. The first 2 colors are pretty warm colors, I did this because as you can see in the photo my original surface is pretty cool. The third color I picked, Starship Filth is a pretty cool dark grey, this is an attempt to just even things out a bit. The whole purpose of this initial layer is to create the general discoloration that comes from exposure to the elements. This weathering is applied all over the model and will change the final color, so when choosing your base color, keep in mind that it may be different than what you intend the final color to be.
When you start of doing this method, pic an area to start with. It is good to work in small areas, this will help enhance the surface discoloration, and keep things simple. This is an image of the area I will be working on before applying a layer of mineral spirits.
The process is started by dipping a wide flat brush into the mineral spirits and then "wicking" as much of the excess off on a paper towel. Then take this brush to the area you intend to weather and brush the mineral spirits on to the surface. Here is the same area with a coat of the mineral spirits. This is probably a bit more than I should have put on, but I was juggling a camera in all this, I actually let this layer evaporate a little before moving on. You will notice that the surrounding areas are flat. I prefer using a flat surface when working with oils, I know there is a lot of back and forth on this topic, but the way I look at it is canvas is a flat material, so maybe keeping my surfaces flat will help me work with the oils better.
The next step is to randomly apply the chosen oil colors all over the area. There is no rhyme or reason to this, it is random and will all be blended together to create a nice, discolored surface. I keep as many brushes handy as colors I am using, that way you do not need to rinse between colors. As you can see from this photo as well, you do not need to be pretty about how the dots are applied. Also a word about color choice, there is no right choice. If I wanted to enhance the cool look of the original surface I would have gone with dark browns and blues and maybe some green, but I choose to go warm so I went with reds and yellows, the choice is yours, experiment and don't be afraid to mess up, you can fix it easily with oils.
The next step is pretty simple. Get yourself a second wide flat brush (remember your first one was used to prep the surface, a second one will be used to blend the surface), dip it in your mineral spirits and "wick" as much of the excess off onto a paper towel, you will need to experiment with how wet you want your brush to be, but the basic idea is to begin to work in a vertical motion working your brush up and down blending all the colors together. Working “up and down” will simulate streaking, rain marks and grime. You can move in any direction, but it would be best to move in the direction that gravity is working relative to the model. If your brush is to wet, the colors will come off in one or two passes. If your brush is to dry, you will smear the colors all around, it really is about finding a balance that reflects the look you are after. I like to work is small sections at a time, it helps create variety in the overall appearance and allows me to easily step away for a bit and come back again if I need too.
You are basically going to keep working the area back and forth creating and building the streaking effect.
Here is an image at about the half-way point. I have completed the center cockpit area and the surfaces to the left of that. You can see the clear difference between the left and right side of the model. Notice how the chips on the left appear now to look more natural and the surface color appears blotchy and weathered in a very subtle way. Even the decals now look less like decals and more like they were painted on.
Here is another image showing the top completely weathered. At this point the model will be allowed to dry for 24 to 48 hours, and then sealed with an acrylic coat of Vallejo Matte Varnish and Future Floor Polish. I will then move onto discoloring individual panels to really add some more depth and variety to the surface of the model.
The last thing I want to show here is a side effect that results from weathering this way. Take a look at this image
Notice how the oils paints have collected in the cracks and crevices of the model, it has created an indirect panel lining result. I think that this adds to the overall weathering, and it would be very easy at this point to enhance this effect.
Redfinger
Here is another re-posting of some work;
So this is not a "mini" but it is a miniature version of a model so I thought I would post a few pics of it here. It is a 1/35 FAMO Sd. Ah. 116, the thing has over a 1000 pieces!
Here is a link to a little about the kit itself - http://www.tamiya.com/english/products/35246famo&sd.ah.116/famo&sd.ah.116.htm
And, here are a few images of the build up and some weathering, I had to scratch build some detail, it is not perfect, but it definitely looks better than what it was and gets the point across.
A.
Redfinger
Update on the Droid Sniper;
One more little mini update to bring everything up to date of what I am working on. A few months back I purchased a 1/9 Droid Sniper from Industria Mechanika. I noticed it is now available in the Cool Mini or not shop, I hope I see more posted! It is a fine kit and presents a lot of opportunity for some fine modeling and painting techniques. It is my hope to try and work with some of the techniques that were used on the Hush bust. I am also toying with the idea of using the sniper rifle as a base for an assault rifle and making the droid more of an assault style droid, along the lines of Elysium. Take a look at a few images here;
An overall shot for some size comparison. The droid is quite long and lean.
The casting is pretty crisp, but I still needed to define some of the panel and seam lines a bit, toothpicks work great for cleaning them out and smoothing things over.
I used some left over photo-etch details and some ball bearings to add some detail to some of the hard points on the armor.
Lastly, I really disliked the lack of detail on the feet, and how soft they looked. About an hour later and some plasti-card and superglue and I had this;
It is a subtle detail, but I think it does a lot to enhance the overall look.
A.
Redfinger
OK so now for something new! As I previously mentioned, I am converting the droid sniper to be more of an assault model. That means he needs a side arm to accompany the rifle. I wanted to make a pistol that would compliment the sleek look of the droid, but at the same time have a utilitarian feel that also follows the feel of the droid. As I got to thinking about it, when it comes to sleek, and utilitarian nothing beats a 1911. So after sourcing some images, and some cutting and some sanding and some more cutting, I came up with this;
Here is a mock up of where it will sit on the droid'
Looking at it, I can see that the trigger is too big, that will be cleaned up, I also need to smooth things out a bit more as well. Grips and other misc details need to be added to finish rounding out the pistol. I will make some kind of holster that is either integrated into his leg, or is attached via bolts or something. The other leg will have a similar mounting, but it will be holding clips, I may throw a grenade or two on the hips as well. More progress was made on the rifle, but nothing worth showing at this point.
A.
Redfinger
Back with an update on the FAMO, been working on this project for someone else. This is a beast of a kit to build. I really was not trying to go for "super detail", just adding bits and pieces to help the over all look, there are also a few photo-etch bits spread out here and there as well. Nothing to really show from the build, I did however magnetize the rear bed to the frame. This will allow the rear bed to be removed, so that the winch and detail underneath can be observed;
I already posted pics of the drive train, once the drive train was completed the frame and forward cab were coated in Tamyia German Grey, and given some soft highlights.
Then some paint splatter was added to mimic dried mud splashes
I then mixed up some buff colored oil paints, and some dark earth brown tones as well and began to weather the engine compartment and frame, I then glue the drive train in place and attached the front cab, here are a few images.
As you can tell from the photos there are still pieces that need to be cleaned up and weathering that needs to be touched up, but for the most part things I think I progressing well.
I am curious if everyone thinks the chain is in scale? It is the largest chain I have in my bits box, I think it works, but I am not military modeling expert.
A.
Redfinger
Got some work done on some Warmachiine Cygnar models today. All the colors are blocked in on Darius
The blues and whites are just about done. There is still some tidy up work to do around the face, and the metals all need to be weathered. He is being painted up to match this fellow I did a while back;
The weathering will be on par with this guy, just a little rust, and the basing will be the same as well. Thanks for looking.
A.
