Removing "varnish goop"
archreptile
Right, so I spent ages working on a marble column.
I decided it needed gloss varnish. I've been using testors dullcote spray and windsor and newton matt varnish without incident so got a batch of windsor newton gloss varnish and put it on.
Seemed to work OK although never really tested it to see if it had hardened.
Put it in a semi airtight container and continued my work on my diorama.
I suppose its been a bit warm, temp in the room probably getting up to 30deg C.
Opened the container over the weekend to find the gloss varnish had turned liquid - basically reverted back to its liquid state.
I left it out for a few hours but no change.
I've recently been experimenting with a mix of tamiya X22 clear and X20A thinner through the airbrush which seems to give a great gloss varnish effect so I sprayed this over but still nothing. I've now done 3 coats of this and my column is still coated in goo.
Any ideas as to how to get rid of this? I'm really hoping its not a strip needed. I'm thinking of some artists spirits or turpentine but that's going to affect the paint...
Warm soapy water and cotton buds, should be your first cleaning attempt.
Failing that go to W&N's site they have a contact link for enquiries.
archreptile
Bugger, the goop is unchanged. The problem with windsor and newton is that I have compounded the issue by spraying additional varnishes over their varnish.
I'm going to attack it with spirits and the consequences be damned
archreptile
As closure to this thread and as a lesson for future, turps did nothing at all to the goop. I then tried isopropyl alcohol. The good news is it removed the goop. The bad new is it removed significant amounts of paint underneath.
Live and learn
pretty much anything strong enough to remove varnish will probably take off the paint as well - and may harm resin/plastic minis.
