Savage Giants
Daimyo79
How will th extr attacks from the Giants work. I'm assuming that it will be _1 for every woumd still on the model ( I've seen spme discussion that people think it's the opoosite ).
Daimyo79
Are you sure............ each model has a set number of wounds. I cannot see where it says specifically which it is .
Alliser Thorne
Wounds are something a model suffers, not something they start with and lose:
Wounds, Pg. 24
Some units might have Innate Abilities that state each model in the
unit has multiple Wounds (see Innate Abilities, pg. 10). When that unit
suffers Wounds, they are distributed exactly as normal, except each
model is only removed when it suffers the listed amount of Wounds.
Wounds cannot be spread across multiple models in a unit. Whole
models must be removed.
Example: A unit of Stark Outriders has an Ability that states that they have
3 Wounds each. If the unit suffers 4 Wounds, the first 3 would be assigned to
1 Outrider
, removing the model. The remaining 1 would be assigned on the
next model, placing a Wound token on it, but it would not be removed until
the unit suffers at least 2 more Wounds.
If units with Wounds are ever healed, Wounds would first be
removed from existing models.
If there are no currently-wounded
models, and models have been destroyed in the unit, then a
model is restored to the unit, with Wounds based on however
much it was healed.
