Originally posted by Naukhel
So, after doing some decent hair in green stuff, I\'m getting bolder, and am going
to try to sculpt something original. Using Sculpey...
Okay, tip #1: use an armature and do something to the wire to make it rough enough to have the Sculpey adhere.
When adding things on, do I bake the piece, add on, bake again, or do I have
to put it all together first, and then bake it?
Well in the spirit of \'too much wet putty is asking for a thumbprint\' I\'d advise working in stages, but it\'s not that simple with Sculpey and the like.
One of the major problems with Sculpey, SS and other polymer clays is in doing transitions from hardened clay to fresh clay. The diluents help in this, up to a point, but many sculptors resort to switching to two-part putties for minor revisions.
Tip #2: you can blend polymer clays with two-part putties to get something like the best of both worlds. It helps toughen up the baked clay for a start and although you get a looong working time you still get the stiffening up toward the end, that helps doing certain kinds of details. Personally I would use about a 1:1 blend to start with myself, see how you like it (used straight Sculpey\'s texture and feel is not something I\'m fond of, although obviously other people have no problems with it).
Just how much baking can this stuff take before I\'ll be ruining my work?
Keep the temperature carefully in check (bake at a lower temp, for longer) and you can bake more than a few times fairly safely.
Tip #3: you can harden these putties in boiling water if you want to, save the chance of scorching thin sections or protrusions.
Sculpting in polymer clays is one of those things that you really want to read tips on before you get started as it\'s quite easy to waste time doing something that won\'t work right (so don\'t try to reinvent the wheel). Thankfully there are
a lot of resources out there, both in the mini world and in other areas.
