Shifting in combat and Dragon’s flight
Is shifting in combat a movement that can trigger Dragon’s Flight? It appears to meet the definition as the tray is physically repositioned as per the definition of movement in the rulebook. However the rulebook also says that you can’t end a move within 1” except when charging, which might indicate that shifting in combat is an exception to the general movement rule as shifting in combat must always result in you ending the move within 1” of an enemy unit.
Many thanks.
Bazzu
Many thanks.
yes a shift is a move as stated on pg5
whenever a tray is physically repositioned by a rule including pivots
Thanks but I’m really looking for an official answer. I know what the rulebook says, I referred to it in my question.
As I also said though, if that’s the case it has potentially wider implications as any move other than a charge action can’t end within 1” of an enemy unit. This would appear to mean that unit’s can’t shift in combat if doing so would mean that they would end within 1” of an enemy unit. So I would also like Michael to address this point (assuming he agrees with the first point) as literally no one is playing the rules like that at the moment (at least competitively).
Bazzu
the combat shift and the ranged shift and the shift from other sources different things, they have their own rules.
The combat shift rules supersedes the one inch as well since it s written on its own, whilst the other shifts are subjective to the 1 inch
but all of them count as a move and all of them would trigger dragon flight
That’s not true at all. The rules say:
“Units may never end a move within 1” of an enemy, except when moving as part of a Charge action (see Charging: “Roll Charge Distance and Move Attacker”, pg. 16).”
If realignment is a move then there is no distinction between realignment and any other move (other than a charge) as far as the 1” move rule is concerned. I accept, by implication, the 1” rule would not apply to any unit it is engaged in but there’s nothing in the rules to say that this wouldn’t apply to any non-engaged enemy units. This is why I’m looking for an official answer and not what other people think.
Bazzu
pg 15, it explains how to do said shift and starts the last bullet point with..........Once these moves are completed, etcetcetc
the only limitation is the one unit engaged.
If pg15 still does not solve your issue I hope you get a reply from game dev
I noticed that now you added the part of the unengaged unit, that no I don t have a reply for it but initial post did not have that condition
titfilou
Moving is moving... you're here... the second later you're there... you moved. Concerning "Not ending a move at less than 1" i would say you can't shift if it would end with your combat unit less than 1" of an enemy unit and is not part of a charge action.
