signatures
please tell me where I can set up my signature and also how to add my ranking when I post comments on galleries and forums.
thank you..:)
supervike
Click the USER CONTROL PANEL (upper right of this screen)
Once there click the EDIT PROFILE tab
Scroll down to the SIGNATURE area
To enter your rank use this code:
<IMG SRC=http://www.coolminiornot.com/rank.php?name=painterboyroy>
Click EDIT PROFILE to save changes.
The rank will only work if you have had at least 5 images each with over 50 votes.
Good luck.
uberdark
vikey,
i just tried the click and pasting of painterboyroys sig, but put my name into it and couldnt get my sig to show my ranking. could you help me some please. mucho thanko!
supervike
Ok, I think I got it now.....
GO TO the SETTINGS page (top right if you are in the forums)
Click settings, choose EDIT SIGNATURE
In the TEXT box, type in
Here is my ranking:[IM]http://www.coolminiornot.com/rank.php?name=uberdark[/IMG]
(change the first [IM] to , otherwise I couldn't show you the code)
The few times I tried it without some accompanying text, it didn't want to display (it SHOULD show up in the 'preview sig.' area. Then after I did it with the text, it took a couple of 'save signatures' before it showed up. I don't know if there is a timing issue, or if the text is necessary.
Let me know if you have any issues.
