Space Marine StormRaven Project
Numinak
Hello all. I've watched for a long while, but felt it was time to share my recent project which was inspired by others I've seen. That is, to build a StormRaven that doesnt' look like a flying Land Raider.
The entirety of this build uses only the Valkrye kit, 2mm plasticard, and two unused pieces that come from the chimera kit (endplates that are included for if you build a Basilisk or other siege weapon but otherwise useless to the kit).
The first thing I did was to tack the body of the Valk together. The endplate above the main ramp was cut and raised up to give it a bit more height, then plasticard was shaped to fit the angle and height of it and drawn back to the midpoint on the cargo area. I also cut off the shaped portion on the 'front' of the cargo pod where the cockpit would normaly hook too, for use later.
Next, I took the wing struts, cut them down just head of the wing mounts, and turned them around (so the swept wing would be going backwards.). I glued them on just above the doorways so that the wings would sit level when the model was on the table. This made it so the angle was just right on the inside of the spars that I could cut a single piece of Plasticard, running it up to the previously constructed cabin in one smooth line all the way down (minus a 2mm cut left just below the wingspars to allow for a top piece to sit on). Also, as part of that single piece, I also cut it down to cover the sides and extend the hull backwards.
Next I cut a piece that would fit and cover the top of the spars, from the rear all the way up to the newly raised cabin area in a single piece. While that set I took the time to assemble the wings and chop the engines down to fit on the wings. The wings required some minor shaving of surface components to make them fit smoothly. At this point I also cut a pair of triangles of plasticard and put them up on the sides of the cockpit, taking away that squared edge created from the rear compartment.
At this point, I cut a few more pieces of plasticard, and fitted them to the lower half of the cargo area, finishing the extension on the angled bits and the floor. I used the intake on the back half of the top as a base for the tail assembly, then used a few tailpieces to set up the 'T' of the tailwing. The rear was also finished at this time, the cut bits being mated to the rear and sealing up the cargo area. Some cut and shaped plasticard was added, to give it the look that it could open to disgorge a dreadnaught.
I put a few other bits on such as the landing gear and started cleaning up the mess I'd made. Added rivet holes and filled in the gaps on various pieces. The cockpit halves are cut and modified a little bit, and used as secondary covers for the engines and 'wings' of their own right.
All that's really left at this point is finding the weapons I need to fit them onto the bird, and I'll be ready to paint!
Think it was worth my time to make? :)
Numinak
No weapons yet, as I said above. I still gotta find them so i can install them.
It has rivets along all the plasticard parts, but they didn't show up in the picture.
Not sure what you mean by profile, do you mean the book stats?
cassar
BALLSCRATCHER
seems to be progressing well these things seem to be taking off in a big way, pardon me for the pun, will be interested to see how yours turns out
Numinak
I didn't! That's the great part of this, I only used the Valkrye and plasticard. No landraider was involved (although I initially was going to go that route, but I kept putting it off because I didn't like the look). I notice you didn't go for the extended cargo section, going to put the clamps in the open area in back?
Im going to try, friend posted me a thread to someone else conversion which is nearly identical to mine! And he did things better, plus the clamp looks cool. Im wick with plasticard however.
(i should have had a better look at your pics, no landraider there!)
Numinak
Here we go! The final rendition, with the advice of a few people for final details (including GW store manager).
As you can see, the twin-linked AC is mounted on each side of the nose, allowing them to clear the immediate area of the loading ramp for quick departures from the front. The TLHB sits turreted on-top. The Missiles are mounted under the wings, two to a side to keep balance.
On the rear you'll notice I added on 'magclamps' to hold the dreadnaught, or pull him out of the rear ramp for quick deployment. Ignore the bit of red, that was a failed attempt at using the airbrush to paint the base color on. :)
Well, Enjoy!
Meph
Cat-herder Extraordinaire
Looking good, man. That's a very nice conversion indeed. Now we're all exited for the painted version! :D
