austinio
OK, so I had some great support on improving the paint job on my last mini and someone suggested I try a WIP to detail my technique so people can offer hints on improving it. Hopefully some might also find some useful beginner tips that I have already picked up along the way.
I used to play Space Wolves and Eldar 40k when I was at school in the early 90s, but I stumbled across them in a cupboard in my parents house last year, damaged and scratched and decided to clean them up a little and replace the missing parts.
I painted a couple of replacement minis I bought on E-bay and found myself loving the painting much more than I used to. I'm now a good 6 months in and starting to see some real improvements in results. I've around 100 metal eldar and 100 metal space wolves, all from the 90s, most that were really badly painted by me back then ( see http://www.coolminiornot.com/357692 ). I have stripped most of them and painted about 20 so far.
Here a few of my latest favourites:
For the WIP, I've picked a fairly simple special character - a Wolf Guard (here is the Eavy Metal version: http://wh40k.lexicanum.com/mediawiki/images/d/d0/Wolfguard1.jpg ). It should allow me to document my technique without it being too long or detailed a project. I'll be able to show some blending on the armour panels, skin tones, sword blending, gold, bone, gems and fur:
I'm going to post step by step - so here is step 1 - preparation:
I have stripped the mini, using brown Dettol (http://www.amazon.co.uk/Dettol-Brown-Liquid-250-Pack/dp/B00D42ZN30). You just leave the mini (metal strips really well, but plastic can work if you don't leave it too long) for 24 hours or more in the stuff neat, then scrub off the paint with a toothbrush. Then I douse in fairy liquid, scrub again, then continue scrubbing under a hot tap. The fairy liquid helps to remove the painty gunge before the water causes it to re-solidify. This sometimes leaves some tiny bits of paint which I pick out with a toothbrush, or a pin for the really stubborn bits - taking care not to scratch any surfaces.
Final preparation is a spray with citadel white undercoat:
I'll continue to update this step-by-step as I paint this guy. Next post should be after base-coating - I'll also describe my brushes, paints and wet-palette set-up and all of my roughly planned steps - subject to change:
Step 2 - Base-coating
Step 3 - Inking for shadows
Step 4 - Mid-tones armour
Step 5 - Highlight armour (2-brush blending on larger areas) - line-highlights on top
Step 6 - Highlights on skin, gold, silver, yellows, reds etc.
Step 7 - Blending sword
Step 8 - Ink fur
Step 9 - Final highlights, eyes and gems
Step 10 - Base with green paint and flock
Step 8 - Ink fur
