Spiderwebs and cocoons.
Aoroi
So while setting up the decorations for Halloween, I have used a "Web Caster" gun. Basically a hot glue gun with a variable strength air hose attached. This got me thinking, are there any good tutorials or ideas on how to make spider webs in trees or spider victims cocooned in webbing. I would love to be able to just spray them with the Web Caster, but I know that will not work, and in plastic miniatures could actually melt them.
Aoroi
Thanks, I will look for it. Do you happen to know a name of what the material is called? I tried to Google it but limited to no luck so far.
I think the white fibrous filling is unspun polyester. But cotton wool could work okay too, for the cocoons at least - the end of a Q-tip sure looks cocoon-y.
Mallows
You can also actually buy something called "spider webbing", like what they use for actual halloween decor. You could probably find it almost anywhere this time a year... Walmart/ target (depending where you live!), any hardware store.
Good luck!
