Does anyone encounter this problem? I notice that when I spray my mini\'s with GW black primer... there are like random tiny black strings that pop up... could I be spraying from too far away???
Typically I shake and roll the can for like 2 minutes, and spray short long range bursts of the can from different angles, doing 2 to 3 coats. Often, with a metal figure, I can see tiny lil specs of metal through the primer... so I assume I am putting on VERY thin coats...
Should I wash my mini off with soap and water between each coat????
