Steampunk Figure Paint-Along
Maenas
off:
in the background you can see a delicious sweet: homemade green tea chocolate :) I just love it (altough it's not cheap because of the needed green tea type (macha))
Pass me the recipe pls!! ^^
I like the googles of both. Also the subtle (macha inspired?) green of the top seems perfect. Are you going to work on the "texture" of the wings, I cannot see if its there already sry.
MAXXxxx
no, I'll leave the wings as they are. Some center lines are picked out though, but not all. And I definately don't have the patience to paint fine lines on each feather for the structure.
offtopic now: recipe. Extremely easy to do (except 1 part, but that doesn't affect the taste)
you need: 400g white chocolate (I bought 4 100g bars, 1€ each), 25g butter, 125ml (heavy) whipping cream (I used 12% coffee cream), about 25g Matcha (the most expensive part, 100g pack costed 22€, so whole pack is enough for about 1.6kg-s).
- chop the chocolate to small pieces (if you use white chocolate pellets you don't have to do this) and put about 3/4 of it to a bowl. btw this is time consuming, for me it took about 45 minutes to do. The smaller the pieces the easier they melt
- heat up the cream, until it just begins to boil, then quickly pour it on the chocolate add butter too
- stir until it dissolves
- now add the tea powder (I used a strainer to avoid lumps ), then mix it more until uniform in color
- now the only tricky part if you are like me and don't have instuments for chocolate making as you'd have to guess the right time. wait a bit to cool and harden, then when it's about 28C (80-83F) add the remaining 1/4 chocolate (they will form the seeds for the hardening process) and stir until smooth again (this will be hard!, at this temperature it doesn't want to dissolve easily, so quite a bit of elbow work).
This is partly the tempering process, that makes the chocolate harder, so it doesn't melt at room temperature. But for a perfect one you'd need extra things and steps I didn't have, so while it keeps it's form, it's not as rigid as the original bars were.
- pour it to a container with baking paper(or plastic wrapper, works too) in it and leave it in the fridge for 4-5 hours. Do NOT wash the mixing bowl before you ate what's left in it.
optional part:
- after you take it out from the fridge, dust it with another 20-25g of grean tea. I felt it's a waste to do, so I didn't do it.
Only problem with this: because the slight bitterness of the tea you don't feel it as sweet as it is and it tastes great, so if you are not cautious you'll eat the whole 400g before realizing it.
And it doesn't matter how you look at it, it's basically 400+g of sugar and fat.
pic without flash :) :
attachment.php
The promlems that I think I need to fix are the same, so no improvement there :D
Pic looks a lot better IMO. You've done an outstanding job, especially loving the bird!
Just a quick tip on the photos again. Your non-flash photo probably doesn't look too different from your flash photo, likely because of all of the unfiltered light shining on it from your work station. While this is the best light to paint by, it is often helpful to step away and either filter the lighting or use an alternate source completely. I know it's supposed to be just a quick shot for some feedback so it's really a matter of preference of course. Just thought I'd mention this because I've seen some possible lighting issues, but hey, my WIP photos aren't very good either so I understand :)
Arkhareon
Wow. Really great work. I agree with BloodFather that the bird and its wings are simply outstanding. But the whole figure is very nice. Really beautiful work.
infelix
I'm about to try to paint the stripes on the pants on Jessica but I haven't really done anything like that before, do you guys have any advice?
Bailey03
I'd start by just sketching them in. Don't worry about nice edges or shading, just get the basic lines down so you can see if the width and spacing is consistent. Then step back and see what needs to be adjusted. When it comes to the finer detail work (shading/highlighting, straight edges, etc) I'd start with the lighter color. That way if you're a bit sloppy with the application and creep into the other colors area, it's easier to paint over a light color with a dark one. In the end, I'll off take several passes back and forth between the two colors to fix any lines that need a bit more work.
If you find the straight lines/edges are giving you trouble, you can always paint one color and then use painters tape to create a temporary mask for the lines while you do the second color. You can often find very thin strips (or cut your own) at art stores and it's easier to use on a larger figure like this.
Bailey03
It's been quiet on this thread for the past few weeks. MAXXxxx and Infelix have done some nice paintwork on their models. Meanwhile I've been slacking. Well, time to fix that. Last night I did some base coating on the Jessica Thunderhawk figure. There is still lots to do, but this quick sketch gives you an idea of what I'm doing with the color scheme. I love the original CG and box art versions, so it was very tempting to follow their color scheme. In the end I decided to try something different and turned to all the Lady Mechanika art that is out there for some inspiration. Below is what I came up with. Overall I'm going for a darker look. I will try to play with the color more as I go, that purple will hopefully make its way into some of the shadows of the black and grey, maybe a little bit in the browns too. The yellow metal for her arms and other details will be a nice contrast against the purple. And, yellow should also make its way into the lighter brown shades. At least that's the initial plan. I'm sure things will change once I get further into it.
Zab
Pale green skin would be awesome with purple and gold. I know she's not an alien, but that would take everyone by surprise o_O
Purple will look great in the gold too Bailey. Sure you already planned this though. I think some red-violet will look good somewhere on her too. You could introduce it as a mid tone, or you could highlight you purple that you are already using with it. I use a red-violet and then glaze a blue ink over it in the shadows. Yummy. Just my .2 pence on color.
Bailey03
Ha, yeah, I'm probably going to stick with a more human skin tone. Though it's an interesting idea, maybe I'll work in some pale green somewhere else on the figure.
I was definitely planning to use purple in the gold, it's my go-to shadow tone for yellow metals. And yup, I want to use some red in the purple too. I'd like a color closer to what I had on Sumothay.
Ah, yes that would be lovely. For some reason I want t see the red-violet worked into her pants as one of 2 tones. Or the boots maybe even. And the leather straps and such could be a red leather. Maybe.
Bailey03
Well, I think you should pick up the figure and get to work on her! :)
As for me, I've made a bit of progress on the figure. I spent an hour or two cleaning up the stripes on the pants. Of course there will be a lot more work on those before the end. I also managed to knock the arm off by accident. But, there's no immediate need to reattach so I'll leave it off while I focus on the main body. After that I went to work on her face and skin. I tried to keep the shading a bit softer on the face to retain the feminine quality.
Bailey03
Thanks!
Gandalf, I hadn't planned to do sheer, although it's an interesting idea. I want to do some pattern work on the purple, so between that and the stripes I'll probably leave it at that. There are a bunch of nice lady steampunk figures from Scale75, so I will have to keep that in mind for future projects.
