Stripping Plastics...
Mungo Zen
Topic says it all. I want input on a solid plastic and resin safe paint stripper. I use acetone for metals and that works great, but it would melt plastics. Any suggestions you have tried successfully would be appreciated.
edit_______________
While I am on it, something ok to clean over 2 part epoxy as well, if it is different.
Mungo Zen
so, with those is there pitting, warping, burning or other badness that can occour to the mini? I know that oven cleaner can do that.
As well, how long do you let them soak, does it eat superglue, and do you have to scrub them clean?
Smoth
pine sol doesn\'t eat super glue but after an hour or two it should allow you to remove your acrylics and primer
S
Sturmhalo
A product called Modelstrip is designed for removing paint from plastics. Get it from your local model shop. I\'ve found it a bit hit and miss though on plastics.
mattsterbenz
pinesol...
after using pinesol on plastics, i wouldnt reccomend it. it eats away at the plastics and leaves a rough surface where there was a smooth one, and ruins detail. it is good on metal though. not sure on resin.
Chrispy
Pinesol, Ammonia, bleach and any aother thing I had around. That\'s my mix that\'ll eat away primer/sealer enough that it becomes a glob of pant that slides off. The only thing is this makes the plastic a little lighter, but could also be from the heavy scrubing I do... Anyways, You\'ll just end up re priming, so you won\'t see it anyways.. :p
frenchkid
I use break fluid, and it has worked great for me. I usually leave my mini overnight and clean it up in the morning. It still needs a litlle bit of scrubing though. I one tryed leaving a space marine in it for one week and it came out all rough and with a lot less details so don\'t let your mini in more then one week :D
Valander
edit_______________
I\'ve used Castrol Super Clean on plastics and resin, and didn\'t notice any ill effects to the plastic. The resin did appear to get a little soft, but hardened up again after a couple of hours. The resin in case, though, was on large lamps, and I don\'t know if it was the same kind of resin used on models.
The good: this stuff strips incredibly well. Soak for a few hours, take it out and run warm water over it and most of it will simply slide off. You can use a toothbrush to scrub lightly, and get everything off the model.
The \"maybe\": Not sure if this will eat 2-part epoxy, since I haven\'t tried it. It does break down super glue, though, so this can be a good thing if you\'re wanting to reglue, or a bad thing if you don\'t.
The bad: Eats flesh almost as well as paint! Make damn sure you wear some latex gloves when using this stuff full strength.
On top of that, it\'s also biodegradable, so you shouldn\'t have any problems just pouring it down the sink (in fact, one of the listed uses for this stuff is as a drain cleaner--and it works great). Not sure about where you might be able to find it in Canada, but you can get it in the US in just about any car parts store, Wal-Mart, K-Mart, etc.
Mungo Zen
Well, I tried 1 mini in Pine Sol and 1 in Easy Off Fume Free oven cleaner. I sat 1 mini in each for just under 3 hours and cleaned them in warm water with a tooth brush.
The Easy Off was pretty good, all the paint and primer flaked off with warm water and a toothbrush, no real loss of detail or anything, some paint left in small cracks and details but not as thick as before.
The PineSol sucked. I used it full strength and it left a gummy residue that seems to be mostly paint and primer gooped on it, but it may also be the plastic is melted. The plasitcard I used to make tiles for the base was fine though, but it hadn\'t been painted yet. I am not going to bother even trying primering it again, it would be a big fuzzy gooey mess.
So, Oven cleaner does work....Next time I get a few bucks I am gonna try break fluid and that castrol stuff. Maybe see if I can find some green klean as well.
