Suggestions for Best Cheap-O Air compressor?
Demihuman
The name says it all. I have a pretty big compressor but it is too loud and requires regular maintenance to keep happy. What's the best e-bay-Amazon-Micheal's air compressor to pick-up for cheap and abuse for the next 2-3 years?
Like, less than $60 ideally, but I could be convinced to spend as much as $120...
Ooh, I need 25 psi.
Thanks!
sunsanvil
78 dB (pretty quiet)
I never put stock in noise level quotes as there are too many ways of expressing them (read: get a lower number). That one for example only gives a telltale "outdoor" qualifier (no weighting, no distance) which means that indoors it will be a lot louder, probably the same as any typical tool compressor. Even if it was an honest "A weighted at 1 meter", I would not consider 78dB quiet.
My Badger TC910 measures 60dB outdoors. In my hobby room it suddenly measures 75dB (using the same metrics). By using damping I've been able to bring it down to a tolerable 65 or so.
Demihuman
OOh E-bay looks like a winner. Keep my fingers crossed. I think that is a decent little machine.
I do have an air compressor, with tanks, its just loud. I was hoping one of these artist compressors could be had on the cheap. I see the master compressors packages with 3 airbrushes and I thought maybe you could find the compressor a la cart for like $40. I hear rave reviews all the time about the cheap airbrushes so I thought compressors might be available too.
Airhead, glad to see you're still around! You got me started with my airbrush a few years ago. Also your advice to give my Paasche VL a second chance was pure gold. When my Iwata was down I did all of the OSL with my VL on this guy:
http://www.coolminiornot.com/360556
It worked great, but you sure have to watch opening it up past that first 1/4 or so...
Scherdy
I've been using the harbor freight one a couple times each month for the last 2 years with no issues.
