Tamiya matte varnish - the bane of pigments?
shakes
Hey all, I finished a mini a while back and had her on a display base. Much of the work on the display base was done with pigments: rich, earthy, browns and oranges. When I went to seal her I used tamiya matte varnish, it completed de-saturated the colours of the base making it dull and lifeless. Having limited use of pigments I had never experienced this, has anyone else had this happen?
I thought it might just be a bad batch so re-applied the pigments and sealed again with the same results.
Does anyone have recommendations on how to seal a mini after pigment is applied without ruining the effect?
Any help is greatly appreciated, Shakes
p.s. I believe a large reason behind the de-saturation is because I used a lot of dry pigment. When I hit it with matte varnish I think it soaked all the moisture right up killing the effect. Might hitting it with gloss varnish first help? Or do I have to apply my pigments mixed with a binding agent to avoid this?
Zab
The sealer will always knock the effect back down. At best if you want, seal your mini, apply the pigment and then hit them with a binder to keep them in place, but do that last if you want to keep the effect. I know how frustrating it is. I went through the same thing when I fell in love with powders. "Wow that's perfect! ~SPSHHSHHHHhhh~ Ahh! What happened to my nice weathering and natural looking dirt!?"
RuneBrush
Are you airbrushing the varnish on or using a brush? I've found airbrushing it on is just enough to seal it but doesn't mess up the finish. That said I use Daler Rowney varnish so it might be different with Tamiya.
